Leak front left side (in front of wheel)
Hi,
I have recently noticed a slow leak from the front left side, in front of the wheel on my 2004 Cayenne s. It seems like water. This is leaking all the time not when the car is running.
any ideas?
any ideas?
I had water coming out from the right side. It turned out my cowl drains were blocked, from leaves that fall in the edges of the windshield and collect over time...horrible design! Do you hear water sloshing around when you go around a corner sharply? Best way to check, is to open the panel for the fuses on left side under hood. With a flash light, you can see if there is water...I am not exaggerating, but I sucked 5 gallons out. Huge PITA. Be warned that all your electronics are in that area, mine was an inch from being submerged. Graham
