Anyone have their front wipers lock up?
Cows-4-Rent
This just started happening and of course we have rain for the next several days.
The wipers turn on okay and make it about 1/8th of the way across the window then get stuck. They try to go on but can't do it. They are working in sync but just can't complete a cycle.
They were fine and I took it in for a detail. I believe they put new blades on it. At first I thought they put the wrong size blade on it the motor didn't have enough juice but they are the same size as the drivers side blade.
I took the blades off the windscreen to see it they worked with not resistance and got the same result.
Any ideas out there?
The timing with the detail may be a coincidence. On two different Audis I've owned, I've had a similar issue. At the time I lived in Minneapolis, and it seems the sloppy, salty road slush would make its way down the shafts of one of the wipers, and cause corrosion, eventually leading to the wipers malfunctioning. The solution was to disassemble the wiper transmission, clean the wiper shafts and bushings with steel wool, grease, and reassemble.
I haven't heard of this issue on the Cayenne, but thought I'd share my experience in case you didn't get much response.
Cows-4-Rent
Thanks Squirt. I'll pull the blades and see what I find down there. I've got a small gear puller and still can't get them off so maybe that is a sign of the corrosion that is causing the problem. Going to hit them with penetrating oil tonight and see if I can get in there tomorrow.
