Driver Lumbar Support
Hi guys i need your expertise right here:i have an 2006 cayenne v6 for about a year with 47,000 miles very clean and bulletproof for now but my lumbar support stops working and i need to adjust!!anyone knows if this use and relay or fuse or going to buy the complete seat motor??let me know guys and thank you all!!
hi the lumbar support on my cayenne 06 stopped working too....so this is what I did:
1) Check if the relay works....if you use the button for the lumbar support and hear a clicking noise that means the relay is working....mine was making a clicking noise from somewhere below the seat so that was ok.
SO the lumbar support has 2 motors......one which pushes the lumbar support forward and back and another motor which moves the lumbar support up and down....are both your motors out or just one??
2) next i opened the the cover on the back of the front seat and took the motor out...its held by 3 rivets....opened up the motor and kinda spun it around and connected it to an external 12v supply and the motor started working....
put it back and riveted it in.
Virk one question:the relay is under the seat or in engine area near the brake pump??and you mention the plastic cover in the back of the seat??its ok mine is broken so i need to fix anyways!!
Mine is a right hand drive so the clicking sound of the relay came from under the seat....for you that would be the passenger seat unless the relay is under the drivers seat ..... You can't miss the clicking sound....the rear cover is held by 3 metal locks.....
[QUOTE=virkdoc;10423210]Mine is a right hand drive so the clicking sound of the relay came from under the seat....for you that would be the passenger seat unless the relay is under the drivers seat ..... You can't miss the clicking sound....the rear cover is held by 3 metal locks.....[/QUOTE
Thanks virk im going to work with that tomorrow
