Air suspension alignment specs for 958 Cayenne
Does anyone have the alignment spec for the new Cayenne? I just had my tires replaced and have done an alignment, but the shop used 08-10 model specs. Not sure if they are the same.
My rear tires were really worn out! The alignment was done at the lower ride height as this is how I drive the car 95% of the time. The rear camber was aggressive, more than -2 degree. No wonder why the rears went bad quickly.
TIA
TIA
I've got the 2012 V6 Manual, Air Suspension w PASM, 21" Turbo wheels. My mechanic told me it's -1.5 deg for rears (looks like more with the big wheels). Slightly less than -1 deg fronts. Toe and caster cannot be adjusted. Who did your alignment?
