Overall Reliability of Cayenne
#49
Engines burn things, burning things smoke. How much and what is what we really need to know. Condensation and/or water in the tailpipe from frequent dealer washing can cause some form of smoking.
Fuel enrichment on start up.
Oil is supposed to get into the top part of the cyl somehow so it will naturally burn some. Different oils will probably produce different results.
Here is a page from the owners manual on the topic of consumption.
#50
Right you are. But for instance blue smoke, white smoke or black smoke are all indicative of specific problems usually. If the ring is shot, oil passes and burns.....there's a dozen problems it could be I suppose. I've decided for peace of mind to have the dealer order a compression test.....if it passes with flying colors, I buy the Cayenne S...if not...I'll keep looking I suppose. Thanks.
#52
Cayennes burn oil, especially on long trips. Keep some in the trunk and don't worry about it. My turbo is a thirsty beast I go through plenty of oil and it's fine, I'm actually getting 20mpg highway and smooth sailing. Last time I filled up on a weekend trip my range said 580 miles and stayed their for quite a while.
#53
I was just told that by a Napleton Porsche dealer too....sometimes I see some smoke sometimes I don't. I am SO glad I went with the V8 instead of the V6. Well worth it! I'll try out the Tiptronic transmission tomorrow.
#54
You will be fine alright. Just keep you check book handy.
#55
Sorry for your troubles. I've had no issues since. I have 26k on my TDI...guess I am due for it to fail. The problem wasn't the necessarily the pump but the calibration. Dealers threw new pumps at it until VW found out how to correctly address. Over on ClubTouareg, this issue has subsided considerably.
#56
Giving this a bump. I'm considering possibly moving to a 2011 or 2013 turbo. What's the group consensus on reliability between the '06 TTS which has done very well for me and the 958's in general, and then these two MY's in particular?
#57
My 04' C S is around 50km on the Odo and had the usual spark plugs issue and I went and replace the coolant pipes (before any issue).
It is a gas guzzler and I may still have issue with the air-conditioner's noise.
The interior is in excellent condition and it just needs a good clay/wax, etc.
I am not sure if I have the drive shaft issue though.
Reliable? I cannot say I am happy on that camp but not unhappy though. Most likely keeping it for a few more years, etc. Drove a 2015 C S courtesy car around for a couple of days while mine was replacing coolant pipes and I could not help stop but wondered on the electronics and their reliability though.
#58
I thought I could give some input. I just bought a 05 ctt with 170,000 miles from SoCal and it was a second owner car. I do have service records all the way back to purchase. The car is great, I was hesitant on buying it at first with that many miles but the owner assured me it still drives close to new. So I went to California from Illinois and buy it, it has been very well taken care of. All issues and updates done, ie the coolant tubes ect. I love my flying pig and I don't know if I so happen to get a good one or there all this way but I highly recommend buying one with history.
Oil consumption is not bad, if you drive it like your on fire it uses a quart every three fuel stops. Drive it normal and it has not used much. Maybe a quart every 1500 mile and on average I get about 19 to 20 mpg.
The only issue I have with is intermittently the warning will come on for the turn signal, turn the car off and it rests and goes away. I think it might be the plug in or possible corrosion on the connector, I have to pull the light and see.
#59
#60
I have a 09 S that now has 94,000km and I have a few thoughts to add which may be of interest.
My extended warranty happens to expire tomorrow, and fortunately Porsche is replacing my CDR-30 radio for the third time now (it keeps rebooting). Phew!
Mechanically, at about 75,000km they replaced the leaking thermostat, then a few months later, the starter motor that drowned underneath it.
I've had a few other lesser issues corrected under warranty such as the washer fluid tank leaking, headlight beam adjustment ,and left side bank camshaft sensor.
Oil consumption is negligible however, but I simply don't believe in the long change intervals Porsche suggest and change mine every 8000km (5000miles). I add about 1/2qt in this period, just to top it up.
An acquaintance with a 08S just had an engine rebuild however (scored pistons) and he had been following the lengthy intervals. His Cayenne had 158,000km at the time and I do believe that the cause was the service interval. It just doesn't make sense to me, because even though the oil may not break down, its carrying and circulating dirt.
Anyhow, I now have the option of extending the warranty another 2yrs, but at CAD$3750 + $300 inspection + 15%taxes (Canada), I'm going to take a chance and pass on it. I do minor service myself and have a good Porsche mechanic who can do the other stuff.
Overall, my real fear is of niggling electrical problems, not major mechanical stuff (I don't have PASM), but like anything else, it's like an insurance gamble.
