brake proportioning , abs , and stuck in park
Old 03-17-2013 | 11:27 PM
fast996's Avatar
fast996
Default brake proportioning , abs , and stuck in park
Well its stuck in park and getting the brake proportioning warning- Help!
Just getting it out of storage, had a trickle charger on her to the battery under the hood- everything was running perfect before storage
fast996's Avatar
fast996
ooopps, 2004 Cayenne S
Old 06-26-2016 | 01:54 AM
Fabianrou's Avatar
Fabianrou
Did you find out what caused it? I just got the Brake Prop. light tonight. 2004 Cayenne S as well.
Old 10-28-2016 | 02:24 PM
touareg's Avatar
touareg
http://www.6speedonline.com/forums/c...ml#post4574700
Old 10-28-2016 | 02:33 PM
touareg's Avatar
touareg
Make sure you check your drains for A/C:
These are the errors you may see:
The harness gets corroded:
Quick Reply: brake proportioning , abs , and stuck in park
