Bi xenon adjustment question
Rocky Mountain High
Bi-Xenon systems found in the Cayenne, from the very beginning, used the Xenon HID bulb for regular lighting situations as well as high-beams. The shutter found in the assembly is opened completely when one activates the high-beam and is partially closed when using the normal dipped beam. This is the factory setup. Flash to pass is simply a flash of the standard high-beam.
To asnwer some questions posed in this thread....
1. This is a factory setup. Bi-Xenon lights were an option in the early model years and the standard lighting offering was the halogen lighting package.
2. No, you cannot adjust the Bi-Xenon lights using any of what most of us would consider "normal" adjustment screws. The height adjustment is handled completely by the combination control unit/ballast located at the back of the headlight assembly. The control unit works in conjunction with level sensors located at the front and rear axles to control where the beam falls. This adjustment can only be performed by someone using the factory PIWIS or PST2 tester. Watching the adjustment process is actually pretty interesting as the car moves up and down if you have PASM.
Toby
Toby
Toby got it right. My Cayenne has bi-xenon lights. The shutter opens fully when the high beams are activated, except for "flash to pass", which is the halogens.
Confirmed. Mere mortals cannot properly adjust Bi-Xenon headlights on the Cayenne.
I was having some trouble with my Cayenne 2006 headlamps. It has a bixenon setup, the light was too dim.
I took out the D1S bulbs and found that the bulbs were a little hazt with a dark brown discoloration around the middle. They are Osram Xenarc 35W
Picture1 is of the bulb with the discoloration
I'm the owner of a 2004 Turbo Cayenne that I bought recently and I am facing exactly the same problem as yours. My Xenon lights are really dim, even the foglights are working better...
My bulbs have the same discoloration as yours, both of them with a 2005 DOT. Before buying some new bulbs, what was the solution you found for your "dimmed" lights, change the bulbs or the balasts?
Hi I did change the bulbs out and there was a difference but it wasn't a huge difference....I think the ballast should be changed too....BUT...I managed to lower the beams because my beams were hitting the sky and it made a hugeeee difference.
But the irritating part was that I couldn't lower the xenons while they were installed so I had to pull out the whole headlight assembly and turn the white screw a few times clockwise to lower the xenons....it made a huge difference....so there are 3 screws...one lowers the xenon projector, the other moves the projector left or right and the third moves the high beam reflector left or right.
Still working on fine tuning it but lowering definitely helped...and after lowering and reinstalling the lights take the key out lock the car then unlock and switch on ignition again
Toby
Toby
Did you lower the beams with the new bulbs or with the old ones?
With the new bulbs....sit in the car and when the xenons cycle watch how bright they are when they are slightly lower...so I made them slightly lower and it helped
Thanks for all the informations provided (in between I tried to clean the lense not much results), I'm going to Germany for vacations nextly and will buy some new bulbs over there (Osram Xenarc Silverstar).
I'll try them when I come back and will give the results on this thread.
Thanks again!
Thanks again!
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
