Side Indicator Lights in Headlight System
I'm puzzled over how to get the lights in my headlight cluster that "point" when you turn the wheel to function. I had been getting a error message on my main display that said "Check side indicator lights", but my side lights on the fenders are fine. I think the message was referring to the "pointers", as every other light is working fine.
My light cluster mini-bulbs that point didn't seem to be functioning, so i had the bulbs replaced, even though they looked fine. They did not show up as existing in the system on the tech diagnostic screen either.
I tried them out tonight but got no results. I had the engine on, put it in drive, and tried turning the wheels with the lights on. The mini-lights did not work. I had low beams on but not brights.
Any ideas?
Any ideas?
OKAY - I'll look for that using your suggested search phrase.
Thanks for the tip on words. I was just going on what verbiage Porsche uses on my screen, which wasn't even clear to me.
Connections were clean, but I may have to clean them again. Replaced the lights too.
