Unable to remove headlamps
When you remove and replace the headlights, do you need to re-aim them? Or does the self leveling feature just work itself out? I'm replacing the headlight seals next week and want to know if anything special needs to be done once I re-install the headlight.
I do not believe so as I had one bulb out and back in, and when it started to work again (days later after ordering two bulbs) it re-leveled itself as I watched it on the garage door.
edit: would like to know if the bulb metal base to shielded wire connection just pulls off or is there a release ?
Thank you,
Dave
Thank you,
Dave
