My plastic coolant pipes are aluminum...
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
On another note...in the process of replacing the leaking coolant hose just beyond the back of the engine he tore a couple more hoses getting it all apart because they were glued at the fittings. Also a t fitting was crumbling so we are replacing all the junk beyond the plastic coolant pipes that have been giving everyone problems. Lately I have been seeing a number of posts about leaks at the back of the engine. Might be a good idea to have a look back there if you have the manifolds off. Not easy to get to stuff back there though.
Eric
Glad that he had some issues getting the hose out because it resulted in him finding the plastic t thingy.
There was another thread where i believe a dealership quoted $3700 to replace this part saying the engine had to be dropped. I am here to report that it does not have to be dropped. My mechanic said when he worked at a dealership they did this type of repair without dropping anything but the dealership would charge for it anyway. Surprise.
It is a pain to get to though. HAve to remove manifold, coolant pipes and mounting bracket at back of engine.
Eric
Eric
