2005 Cayenne roof leak
Old 07-07-2015, 01:28 AM
Fabianrou
Fabianrou's Avatar
'04 - 955 here. How hard was it to remove the headliner? Did anything brake in the process like clips, etc? I had about 2 inches of water in the passenger seat last year. Im talking gallons in there!! Turned out to be the drain inside the wheel well and was backing up through the A/C drain hole. That was the biggest mess I had ever seen inside a car in my 49 years. Now I clean the drain once a year. Since reading this I will do the roof torx screws like you did as a preventative measure. Will I need new gaskets?
Old 11-03-2015, 12:50 PM
Ken Tan
Ken Tan's Avatar
Hi,
Where exactly are the torx screw on the roof rack channels? I have water running down from the A-pillar and I do not have a sunroof. I'm guessing that's the only place water can be running in from.
Thanks.
Quick Reply: 2005 Cayenne roof leak
