Rear Driver's side door not locking
Don’t know if this applies to the 2003.
My Cayenne 92A Back Door would not Not Unlocking – SOLVED
My rear back door would not un-lock with the remote. It would lock fine.
There are 4 fuses that control central locking and unlocking, 1 fuse for each door. All 4 fuses are called CENTRAL LOCKING CONTROL UNIT/POWER WINDOWS”
Pull ALL 4 fuses out at the same time, leave them out for 5 mins and put all 4 back in. All my door ops then returned to normal.
In the 92A
2 fuses are LH side of dash #16 and #30.
2 fuses are RH side of dash #9 and #11
In the 92A
Was wondering if this fuses thing fix the problem?
Mine here is using remote it lock all four door but dint unlock the passenger rear door..
If I'm using lock/unlock button inside dash.. it won't lock the rear passenger door..
So weird... And I have change new battery bty..
And error code I have got is
881202 Key Battery Flat code stay active...
Anyone can fix this issue ?
Some help here would be !uch appreciated guys...
Seems really hard to find resolutions in fixing this cayenne 92a around internet..
I'm facing the same problem here..
Yes, the fuse reset did fix it for about 8 months but then it came back.
I then pulled the door trim off and pulled the door lock actuator out. It had a really thick, dirty grease on the moving parts so I cleaned it all off and then put a light lithium grease on it. It has been about 2 years now and I have never had a problem again.
If I did have the problem again, I was going to buy a door lock actuator online and change it.
