2004 PCM issues
Old 08-13-2012, 11:33 AM
PD Monkey
PD Monkey's Avatar
Default 2004 PCM issues
I've had my Cayenne for about a month now and twice the PCM won't work. It "appears" to be working (alll screeens are on) but no sound. I've turn it on and off, no luck. Each time,I've turned the key on and off a few time it came back on. Any ideas on what might be the issue? Or just deal with it??
Old 08-13-2012, 01:10 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,451 Likes on 905 Posts
I get that occasionally too. It's infrequent though - only once or twice per year.
Old 08-13-2012, 01:37 PM
mudman2
Moderator !x4
mudman2's Avatar
Its a common enough problem on 03-05 models even 06 maybe
No easy cheap solution, we just deal with it and know that if you shut her down and leaver her for 5 minutes there's a good chance it will work agan
Old 08-13-2012, 03:11 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Larry
Old 08-13-2012, 03:21 PM
EnigmaWmn
Just call me Pops
EnigmaWmn's Avatar
Stalin
Mao
Larry
Old 08-13-2012, 03:32 PM
ultramens
ultramens's Avatar
I had the same problem, I have a 2004 CS with 65K miles.... I replaced the battery under the seat and it solved the problem...
Old 08-14-2012, 01:27 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
No, actually that didn't solve the problem.
The amplifier is the cause, based on a random/seldom occurring failure of the micro controller to properly boot load the DSP firmware, resulting in a "no audio output" condition.
Now, the "volume stuck at 11 during an executive test drive" ...
Old 08-14-2012, 01:29 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Originally Posted by EnigmaWmn
Stalin
Mao
Larry
Yes, they all had a gift when it came to "people skills"
Old 08-14-2012, 04:46 AM
Orantes
Orantes's Avatar
It has been discussed many times on the forum. It has happened to my 2004 only once in the past. Waiting for 5 or so minutes is the easy solution. It's a quirk of the car. ITC has given you the source of the problem. Unless you buy a new amplifier, most just live with this issue. Sorry, there's no easy answer....
Old 08-14-2012, 10:13 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Back in the early days, when P!gs were just beginning to roam the Earth, there was a TSB which installed a firrmware update to the amplifier (originally done via CD in the head unit; later done via PIWIS IIRC).
You just had to ask for it by describing the issue to your dealer.
It was not a 100% fix, but did reduce the frequency of the no audio output event.
Old 08-14-2012, 12:37 PM
ultramens
ultramens's Avatar
All i know is when I got the car... it happened multiple times within the first month... then after the battery change.. has not happened since... its been 6 months... not once has it acted up....
Old 08-14-2012, 12:39 PM
mudman2
Moderator !x4
mudman2's Avatar
Believe me its luck, don't be surprised when it happens again
Old 08-14-2012, 01:05 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
Happened to me a couple of times, have not seen the issue again in at least a year and a half.
Old 08-14-2012, 01:14 PM
mudman2
Moderator !x4
mudman2's Avatar
Well that just the result of darn good devious design, can't think of anyone that clever....oh wait !!
Old 08-14-2012, 02:45 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Grasshopper ... don't try and ****** the pebble from my hand when it comes to this topic.
Quick Reply: 2004 PCM issues
