less than 1 week on the road- first warning light CEL
5th Gear
lovely! less than 1 week of driving an '09 GTS and my first light yesterday.. solid CEL ...didnt opened the gas tank as i got a 1/4 tank left, but i re-tightened the gas cap just in case...no luck yet. will see if it clears itself, otherwise into the shop she goes...venting over.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Hmmn, a CEL ..... Let's ask Larry to see what it might be....
And now let's see how he thinks this likely (and usually) ends at your dealership.....
(assuming you ordered option code 1FU, in which case you have the Porsche Design axe under the rear bench seat, along side the compressor)
Nothing to worry about, everything will be fine between you and your P!g.
Enjoy the new car
Enjoy the new car
5th Gear
quick update: (work order/invoice)
Fault code was: P1281 Cooling sys. thermostat performance.
Issue: coolant leaking from thermostat housing.
Resolution: replaced thermostat housing and thermostat + drain/bled cooling sys.
Hope this info helps someone else one day with a CEL issue.
