Help with Build Sheet/window sticker?
Anyone have a connection that could get met the build sheet information (or copy of window sticker) for an '08 GTS Cayenne that I'm looking to purchase - I have the VIN.
Also would like to get the service/repair records (assuming P dealers have a common system that tracks this stuff) as well.
Any help would be appreciated in my quest to become a Pig owner.
Hoping to get this info pretty quick as I have a deposit on the car (long distance purchase) and just looking to verify the equipment and that it has been well cared for.
TIA,
Tom
TIA,
Tom
Moderator !x4
For now the seller has actually come through with a fax of the original window sticker so I'm good on that front. He also got the local dealer to send me a print out from the PIWIS (???) report which shows this car to have had 2 campaigns: 1) high pressure pump and 2) airbag control unit.
I now have two remaining questions, are there any other common issues/campaigns that an '08 GTS should have had?
Also what the seller/dealer did not send me was a record of the service performed thus far on the car. Are these records that are up to the actual dealer performing the service or is there a centralized database that any dealer can access?
Tom
