Air Suspension Error Messages
Only one compressor.
One idea would be to connect a source of air to the little outlet near the passenger seat (the one used to inflate the spare tire).
I honestly don't know if there are any check valves that would defeat this idea.
I also have no clue what the normal system pressure would be (over pressuring the system would be a bad idea).
I tried connecting the air-filler hose which activated the compressor for only a second or two. While the compressor hose is connected, the car will not accept any rise/lower commands. I played around with the air filler for a bit with the compressor cycling on/off, then after a while, I disconnected the air filler hose, then hit the air-suspension switch and got the same "accumulator" message. So, while the hose will make compressor cycle it doesn't seem to do anything for the suspension accumulator.
cheers,
c
cheers,
c
dear OP, i have followed your steps, i had the same issue, i used a very hard silicone to patch my rubber mount and its holding up. the o-ring on my car was still in serviceable condition, so that remained. i ended up spending about $20 for the silicone tube and $150 @ mechanic. DONE, patched up until i can order parts and get them in. Then wait for it to fail to redo !
thanks for the time youve invested in this,.. its working great !
