08 Cayenne GTS ECU Flash
Old 05-13-2012, 01:37 AM
On Pole
On Pole's Avatar
2ndary cat delete is only worth 12hp and 12tq.
Old 05-17-2012, 11:48 AM
s4treg
s4treg's Avatar
Let me know if you proceed with this, who you use and what the cost was.
Right now I'm contemplating starting with the 2ndry cat removal and cold air intake replacement, all bolt-on's.
Old 05-18-2012, 04:20 PM
GTS 6 spd
GTS 6 spd's Avatar
On Pole: FYI on the ECU flash, the "improved throttle response" is nothing more than modifying the electronic throttle to apply a higher % of throttle for a given input. And as most ahve said, the gians are modest and best and will not be noticeable. Anything less than 15-20% is not worth it.
Old 05-18-2012, 04:49 PM
s4treg
s4treg's Avatar
What if one were to combine it with a 2ndry cat removal, cold air intake, and perhaps exhaust (I'm thinking about the later two)? I would think then a flash might be beneficial?
Quick Reply: 08 Cayenne GTS ECU Flash
