Source for Crossdrilled or Slotted Rotors?
I am in the process of sourcing parts for a brake job on my '05 Cayenne S, and want to use slotted or crossdrilled rotors but have been unable to find a source in the forum.
I did find one vendor on eBay but apparently they take solid Zimmermann's and machine them. I am not sure how that would affect the integrity of the rotors.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170554097678&ssPageName=ADME:X:EAC:MOTORS:3160
Does anyone have a good source for slotted or crossdrilled rotors or have experience with ones that have been machined?
TIA
TIA
And why do you want them cross drilled?
The V8 Porschephile
Harvey, like you I scoured the internet looking for cross-drilled rotors for the Cayenne and after speaking to many vendors and mechanics, I was told that machining stock or aftermarket rotors may eventually cause fatigue cracks.
If you really want cross-drilled rotors, go the route of custom-made stainless-steel units as they will last a long time however, you may have to sell your first-born or re-finance the Cayenne to buy them.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Former Vendor
To get the cross-drilled look, you can do some parts bin engineering and put 996 GT3 front rotors on the S.
There is a reason Porsche didn't use drilled discs on Cayenne. Drilled discs are not used on offroad cars. If you stay on tarmac, you can change to drilled discs, but it doesn't make your car better.
the functional reason for both is to allow hot gasses from the pads to escape, hopefully reducing pad transfer. Pad transfer is what many incorrectly refer to as warped rotors.
Slotted rotors are structurally superior to "drilled". Slotted are also a lot less messy regarding brake pad dust.
I run RSS GiroDisc rotors on my 997.1 C2S. I will be changing the rotors on my 2009 Cayenne S to slotted when replacement time comes.
Registered User
http://cgi.ebay.com/ws/eBayISAPI.dll...AC:MOTORS:3160
TIA
TIA
![](http://i213.photobucket.com/albums/cc228/boeing717jf/DSC00146.jpg)
![](http://i213.photobucket.com/albums/cc228/boeing717jf/DSC00145.jpg)
![](http://i213.photobucket.com/albums/cc228/boeing717jf/DSC00148.jpg)
