Carbon Fiber interior trim delaminating
I just picked up a new to me 2008 CTT with the interior carbon fiber package. It is from Texas so experienced some high heat I am sure. The trim pieces on the doors have the carbon fiber peeling up from the plastic beneath it.
Anyone have any tips on securing it back down? 3M trim tape isn't a great option.
The V8 Porschephile
My friend's 996 had a factory carbon steering wheel which cracked due to the heat and UV exposure.
Your best bet would be to remove the part(s) from the door, lightly sand down the lacquered section which is delaminating using 800-1000 grit paper and re-spray with a quality automotive clear lacquer.
The issue is actually the carbon fiber overlay coming apart from the plastic backing that then attaches to the doors.
I solved this by using a heat gun to completely pull apart the 2 halves, used goo gone and sandpaper to remove the excess glue and scuff up the two halves a bit. Cleaned both sides then used 3M trim adhesive and a truckload of clamps to attach them back together, then used a heat gun to warm up the trim piece and form it back so that it doesn't curve out as much towards the ends.
So I guess the carbon fiber option package for 3 grand is actually used to pay for the self help class to learn how to fix interior parts.
