Evaporative Contol System error P0144
I have Check Eng. light and read fault code P0144 which is the evaporative control system. Anyone out there worked with the problem? Is there a common cause? Is an 05 Turbo Cayenne
Just call me Pops
Yes, my '05 CS P!G has "worked" with this problem around 10 times in 5 years.
Tank valve + lines have been replaced at least 3 times. Then the gas cap was leaking. Then something else. Gotta go check.
