Cayenne are hatch will not open, yes motor is working
I have an 04 cayenne and the rear hatch will not open. Yes I replaced the motor last month, and yes I can see it moving the lever in the small opening inside the hatch, but the hatch is locked shut and I can move the lever By hand with the cable on it as I did before when the motor went bad, but no luck, even tried prying it and it moves fine, but the hatch stays closed.
I spelled the first part wrong, to say rear hatch, but you cannot edit the title line.
