Heated Seat Not Working
So i have had this problem that the 5amp on the fuse 39 keeps blowing. At first it would blow only 2 times throughout the whole winter. Recently when i turn the car on the fuse blows right away (All the seat heated switches are at 0). I replaced the 5amp and turned the car on and it blows right away again.
Where should i start to troubleshoot? Under the drivers carpet? Remove the drivers seat? Try a 7.5amp or 10amp instead? Thanks!
Eat a lot of baked beans !
Rocky Mountain High
One of my heated seats stopped working - the passenger's side front seat. I haven't checked the fuse yet. I'll check it tonight.
Sorry I can't offer more insight but don't put in a higher rated fuse, that's asking to release all the smoke bottled up in your wiring. I would be inclined to start looking under the seat for a frayed wire or connection and go from there.
The V8 Porschephile
It's highly unlikely that a 5-amp fuse powers the power-robbing electric elements that heat our backsides. There's a good chance that this fuse powers the relay which powers the elements. I would start by checking the relay to see if the contacts have fused or shorted together.
Makes sense, i belive the relay is under the dash, i will see what i can find out this weekend.
So I found the relay under the dash, I unplugged it, plugged it back in in, replace the 5A fuse and now my heated seats work. Strange, should I replace the relay?
Rocky Mountain High
I'll have to try that...
Rocky Mountain High
My seatbelt chime for the passenger's seat doesn't work any longer either.
