Need Advice on Wheel Spacers...
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Hey guys,
I just received new wheels/tires for my Cayenne S today. They are OEM 21 inch GTS wheels which I found on eBay a couple days ago. I tried fitting one front wheel onto the car, and realized that I need spacers since the wheel is in contact with the brake caliper.
Any advice on what kind of wheel spacers are best?
Thank you so much!
Vinny
Thank you so much!
Vinny
![](http://i753.photobucket.com/albums/xx179/vinnysca/2011-11-03_14-03-38_950.jpg)
i just ordered some from a vendor on another forum. 215$ shipped w/ the extended studs... great price and i think i like that setup better than the ones that have studs pressed in.
Update:
I decided to fit the GTS wheels in the rears of my Cayenne S. I didn't need any spacers for the rears at all. The calipers are clearing the inside of the wheels and the tires are flush with the rear wheel arch.
![](http://i753.photobucket.com/albums/xx179/vinnysca/2011-11-04_16-42-17_346.jpg)
I then decided to remove my Carrera S' front H & R spacers (7mm) and try it on my Cayenne. The wheel bolt patterns are exactly the same in the Cayenne's and it did stick out a bit more than the rears. So I purchased a 5 mm spacer as I have a feeling that it'll be just enough to make the wheel clear the calipers and make the tires not stick out as much.
![](http://i753.photobucket.com/albums/xx179/vinnysca/2011-11-04_16-44-42_312.jpg)
![](http://i753.photobucket.com/albums/xx179/vinnysca/2011-11-04_16-41-49_519.jpg)
![](http://i753.photobucket.com/albums/xx179/vinnysca/2011-11-04_16-44-57_140.jpg)
Vinny
Vinny
