programming trailer module
My 2004 Cayenne S has option 1D8 for trailer towing module prewire . I want to order the module and harness but "dont" want to have to have it programmed so it will work . Some say there's was a plug and play, others say it has to be programmed . Can anyone enlighten me on this difference in operation ? Is it just a chance you take , I am not near a dealer so programming is a big problem ...
thanks Rick M
thanks Rick M
Super Moderator
Needs More Cowbell
Needs More Cowbell
The 1D6 would "work" as a plug and play device, however it was not designed to self adapt between US and RoW configurations.
A search of the forum would have revealed that the 1D6 module would likely be delivered in a RoW programming configuration. A US dealer would then update the unit via PIWIS configuration to US settings.
Super Moderator
Needs More Cowbell
Needs More Cowbell
It was just your lucky day ... I learned a little about 1D6 from Larry before he died.
IIRC, a RoW programmed unit will "work" as a plug and play, albeit you might get some sort of message like "Check Trailer Lights" or "!" on the dash display ...
Only in very rare (and documented cases) will you lose all the lighting ... at which point it's Maglites and Racer's Tape ...
I DIY'd my trailer hitch on an '04 CTT. Turns out something needed to be triggered to tell the ECU it now had a tow hitch. Lucky for me, Loren from RennTech lives nearby with a PIWIS. Took him maybe 5 minutes to code.
