AC Recharge
Anyone know where the lines are to recharge the freon in an 04 Cayenne? I tried the search and found nothing...
Hoping this isn't one of those, "you gotta remove the whole top half of the motor to get to it" kind of jobs.
Thanks!
Thanks!
The V8 Porschephile
Jeff, food for thought.
Lo or insufficient airflow through the evaporator can cause low system pressure readings on your service manifold guages. This may influence you to immediately add refrigerant into the system; thinking that the system fill is low.
Check your pollen filter and make sure it's clean before testing your system.
