TPMS 2011 vs. 2010
I have a chance to pickup a brand-new set of 2011 18" Cayenne OEM takeoff's complete with TPMS that I will use for winter tires on my 2010 GTS.
Do you think the 2011 TPMS will work on the 2010?
Also I believe the rims have a 53mm offset, vs the 57mm offset on the 2010 but bolt pattern is the same. Think there will be any fitment issues?
Thanks!
Thanks!
Admin
The sensors and transmitter have completely different part numbers between MY10 and 11. I am not sure that they will work.
4mm difference in the offset is negligible in a Cayenne using factory 18x8 wheels.
different part numbers, BUT some gentleman on here got his 10's to work on his 11' if i remember correctly.
best case=they work
worst case= sell em for 400 and buy new 10s for 450 off tirerack.
best case=they work
Received the new take-off 18" 2011 Cayenne Rims/Tires/TPMS and just put them on my 2010 GTS.....and.....the TPMS works just fine!
I had to go into the vehicle settings to change the tires settings to the 18's, then drove and within a mile the new tire pressure readings popped up.
So now I have a set of winter tires, but the wife says she likes how the 18's give a more compliant ride than the 21's, so they might stay on (it's her vehicle after all). We will see.
-steve
-steve
