brake pedal switch
Old Apr 2, 2011 | 10:25 AM
mikew968's Avatar
mikew968
Default brake pedal switch
Where is the brake pedal switch on an 2011 cs? i am tring to find the 12v wire from when you depress the brake pedal to install my brake controller.
Old Apr 2, 2011 | 03:09 PM
Andy E.'s Avatar
Andy E.
The V8 Porschephile
Not sure about '11 models but '04 to '10 are above the brake pedal next to the steering wheel shaft knuckle.
File Type: jpg
Old Apr 2, 2011 | 04:27 PM
Frank 993 C4S's Avatar
Frank 993 C4S
My '10 did not have one in that location. I just installed a Tekonsha Primus IQ controller on my '10 GTS which does not require the brake pedal switch. No clue about the '11.
Old Feb 21, 2025 | 07:38 PM
MotorGods's Avatar
MotorGods
Well like everything else on these rigs there are a couple Mysteries I have a 2006 Turbo and the switch is not on the break pedal there's only one and it's under the hood on the master cylinder
