Cayenne Aluminum cooling pipes on sale Great price
#31
Jochy The first part number you listed superseded to the second part number. You were actually only supposed to get one but for some odd reason you got two. Those are for the alternator coolant pipe, as mentioned. As for the thermostat housing gasket, we didn't remove thermostat housing when making our instruction manual, but a lot people do so to make it a little easier to work in there, so we included the o-ring and metal gasket in the kit.
About the coolant gallon subject.,.I found not draining completely the radiator will help to just complete the system with the provided gallon of coolant. Since the coolant is not intended to be replaced.,.,.is not imperative to remove all the fluid, just the amount at the lower big pipe.
(saved by the bell)
