Cayenne Aluminum cooling pipes on sale Great price
http://sonnenporscheoemparts.com
Just ordered mine for 424.00 Over a 150 dollars less then anywhere. The dealer wanted $2800
The DYI is here, would have bought it from them but they are out of stock until next year....and they want 600.00
http://www.ecstuning.com/Porsche-200...ing/ES2501060/
It cost me about $65 in tools to do this. You need your standard 3/8 metric set, with both T and E torque sets...(the star ones inside/out) Oreilly had them for 20 each set.
Total cost w/ tools: $545 dollars...
Working on your own Porsche, and knowing your machine Priceless!!!
Former Vendor
Extra Willing to get my hands dirty...
Are you including o-ring LUBE in my coolant pipe set ?
If not, what can I do? The dealer charges $34 for the whole tube...
Former Vendor
We actually took it out of the kit because it put the kits on back order for the longest time. Click Here to view the item you need. In a pinch you can use some Petroleum Jelly if you have any handy. I would advise getting the stuff in the link though.
I was all set to order from ECS this morning, but the salesman told me they sold the last one 5 minutes before....
looking forward for your reply soon since I'm kind of waiting for your reply.
Is kind of weird to receive a coolant pipe upgrade kit ... and end up with extra parts....
I really thank you for your prompt service and customer service at the time of buying the parts.
(no affiliation etc etc etc...)
See here: http://www.pedrosgarage.com/Site_5/C...ntifreeze.html
I used the Havoline stuff. Neither Porsche nor BMW coolant is anything special or exotic, just need to use the correct product.
at this moment I'm performing the replacement of the pipes, reading the provided manual in your webpage...the procedures does not include to remove the metal place where the thermostat is located. But you sent me two set of gaskets which goes inside such plate. My question is: Why am I receiving in the ECSTunning kit such gaskets if the manual provided does not detail the replacement of such gaskets nor the removal of the plate to do maintenance???
Many shops apparently do not remove the thermostat housing because they've done so many and have a way to clean the outlet before replacing with the new AL tubes. Personally, I had a very hard time getting the outlet what I felt was sufficiently clean even after I removed the T-stat housing, it's hard to work under it. Initially ECS didn't even include the t-stat gaskets but I guess they decided to include them in case the customer decided to remove the housing because you do NOT want to re-use the outer metal gasket.
Personally, if you're only doing one I would remove the housing just to give you access to clean it well but it's your choice. Remember to torque the housing bolts (but it's a very low spec, something like 11Nm but look it up.
If you decide not to remove the housing and wind up with unused parts ask your provider if they will take them back. Not a big deal to me.
Until ECS responds I will answer based on my experience with the task (I've only done it once, to my '06).
Also last night I did not recognize a set of 2 o-rings the kit comes with. Since my cayenne is non turbo, dont know if this is for the turbo model.
Part no. 99 97 0 747 740
The ECS instruction manual does not talk about them. Havent see postings of people talking about such o-rings. I only found 1 oring to replace which might fit the new one... And is located in the metal plate cover where the thermostat sit. Is where the metal pipe connects in top attached with a little screw.
Have you work on those?
Your valuable input will really help me finish today and I will appreciate it for the rest of my life !!
That's exactly what I did last night after posting my question. I researched in the internet and found many people doing it. For me, being my first time working down this hood, it was really needed to remove it. Thank you for your quick reply 993BillW!!!
Hard to tell the size from those pics but they look to me to be the for the tube you mentioned in front of the t-stat housing (coolant line for alternator). Why they sent you 2 I don't know.
I read somewhere here in the forum those should be 2 different sizes... I got one fine but the 2nd one I dont have a clue for what and where to install. Right now I'm working on the big pipe...I come back later with the thread about the o-ring size
just when standing up from my chair...I remembered where exactly I read about the o-rings size and part no.....here the link and here's the copy paste of the thread conversation:
https://rennlist.com/forums/porsche-...es-a-z-16.html
Sure - on PET (the parts system) they're shown on the page for the thermostat housing:
1x - 99 707 516 40 (20 x 2.65) O ring
1x - 99 707 477 40 (19 x 3) O ring
Cost is about $7 for both.
Former Vendor
Jochy The first part number you listed superseded to the second part number. You were actually only supposed to get one but for some odd reason you got two. Those are for the alternator coolant pipe, as mentioned. As for the thermostat housing gasket, we didn't remove thermostat housing when making our instruction manual, but a lot people do so to make it a little easier to work in there, so we included the o-ring and metal gasket in the kit.
