Slight shake/rumble at cold start idle
Hi I'm new to this forum,
I was googling this issue as I'm currently having the same problem with my 2005 Cayenne 3.2 V6 (48500 miles)
When starting the car from cold I too feel the rough running and the rev counter moving from 0.5 to 0.9 and a slight rumble from the engine. When driving off the car sets off in 1st gear also instead of 2nd like normal.
Did anyone ever find a problem with this or is it genuinely the way the vehicle starts up in the cold!?
Cheers
Mike
Cheers
Mike
Hello,
Just picked up my cayenne platinum edition from dealer a month back. Only 3000km on it. The car make strange bang noise from engine compartment when started in cold weather. This only happens when the car is cold and only for initial 10-15 seconds, after that no problem at all. the noise is very loud as if something exploding inside the engine. the reeves start to drop from 1100 to 700 and then go back to 1100 until the car warms up? Took it to the dealer and he couldn't find any issues. Any ideas? you can see and hear the engine in the attached link.
https://www.dropbox.com/s/xnc6ad13bs..._0383.MOV?dl=0
Mine does it at warm idle. I would simply call it a rough idle. Engines with more aggressive cam profiles have always had a bit more of a rough idle. They used to call it a lopey or lumpy idle. It does not interfere with daily driving and in fact provides more power on demand at higher rpm, so why the concern? I happen to like it and think that is one of the bennies of the GTS, vis a vis the S. What's not to like!!
The major concern is very loud banging noise from the engine, it seem as if some one is literally hammering the engine from inside and it would crack open. Also the as soon as the engine starts to knock the engine starts to loose power and revs drop. This only happens for may be 10 seconds and then engine gets stable again. but these 10 seconds are enough to scare one. it literally feels like the engine is about to explode. You an hear the banginng/knocking 0:20 to 0:28 min
You can also hear the engine start to loose power.
I am no expert but can you narrow the sound to location in the engine bay? Sounds like things shifting like an ABS cylinder or something like that?
Sound is from the right side of the engine, and the sound is in idle position right after starting the car for the first time in cold after sitting there for 16-20 hours. The revs also drop(600-700rpms) immediately as the knocking starts and get stable back at 1100rpm once knocking goes away to continue warming up the car.
I have the same issue with my 2014 cayenne base...only has 28000 miles...on cold start makes almost a rumbling, rough idling or misfiring sound at cold start.. kinda like vacuum leak sound. Anyone has a specific experience like this with a specific solution done by the dealer. I am brining my car to the dealer still under factory warranty but I don't want the dealer to tell me everything is ok with that sound..if I knew the specific cause at least I can suggest for them what to check on
It does sound bad like something is misfiring. I still own the Cayenne and can say that nothing it still is reliable and nothing has come about the cold starts.
Let us know what they say for your year. ..
