Interior lights wont turn off
Hi, usually when I lock the car, the interior lights turn off but now they don't seem to want to turn off anywhere even when I turn the engine on. It seems it thinks theres a door open but they are all closed. What could be causing this? I mean, does the cayenne even tell if you if a door is open? It doesn't give me a signal when a door is open which I found pretty weird. Also, for some reason the "!" light is on but there is nothing in the warning section of the main menu?
Thanks for the help.
Edit:
Fixed, somehow the rear window hatch was open (not the trunk)? How do you even open that I mean I just pushed it in until it secured and the lights turned off but is there a way to open this thing?
Other thing, is there a way to make it tell me when a door is open instead of beeping and flashing this thing for half a second when the car starts moving. I mean, the only reason I figured it out is that I went for a little drive and it beeped showing something in the trunk but why cant it tell me right away before I start driving? Unless that's just how it is
Edit:
Thanks for saving my sanity! I was going crazy with the interior lights staying on after getting out and locking the car until I found your post.
I also had the ! warning signal on and figured out that you were right. The rear upper lid was not closed properly.
Opened it, closed it again properly and my sanity is back...
