Thinking about adding an aftermarket reversing camera... thoughts?
One of the options I wished I ordered on my '11 V6 is the reversing camera. After having it on my previous car for 2 years, I grew accustomed to using it. Initially, I really missed it on the Pepper, but now after 7 or so weeks, I'm OK without it.
That said, I recently discovered Nav-TV makes an aftermarket solution that appears to work just like the OEM version. I spoke to the Nav-TV folks and they recommended a local dealer. The price is reasonable, however, I'm a little weary about having someone get behind the PCM for the install, fearing potential warranty issues. I haven't had any aftermarket work done on any of my cars in 15+ years, so I just wanted to get some of your thoughts. It doesn't seem like an overly complicated job, but again, don't want to run into any possible electronic issues down the road or getting denied of any warranty claims should something come up.
Thanks in advance for your thoughts.
Beuller?
I have no real evidence to back up my opinion so this is totally a gut reaction, but if it were me, I wouldn't want anyone messing around behind the dash of my new Cayenne. I'd personally pass on the camera, FWIW.
The V8 Porschephile
I've also spoken with the Nav-TV folks about installing one on my GTS. To date, it seems like the only logical choice in back-up camera systems. I was about to pull the trigger on one until I read on the 911 forum something about error messages appearing on the screen and incompatibility issues that require unplugging the NAV-TV module whenever servicing the vehicle. Not my cup of tea. And with the Cayenne being infamous with electrical issues, I refrained from doing the mod.
Thanks guys, appreciate the feedback. Leaning towards passing as well...
I recently installed the Nav-Tv unit in my '09 GTS, I am using it with the ebay 'special' plate light/camera CCD version and so far love it, the image is perfect. The instructions were not complete but close enough. It might just have been the extra wires from the bose system.
Running the wire was not difficult from front to back however I spent about 3 hours getting from the rear corner to the hatch routing with the factory wires.
All in all I am a happy with the package and do agree its the only way to go.
Robert
Robert
Robert
Robert
Unfortunately no pictures, as for the instructions form navtv they did not include the wire running, but my previous post was referring to the moving the fiber optic and an additional set of wires (assuming bose) from the factory clip to the navtv adapter.
As for running the wire I already had the kick panel removed per navtv, so I just ran the wires (switch power, gnd, rca) to passenger side door sill, I did not have to remove the doorsill just pushed the wire under, it only bulged a little by the front seatbelt.
This worked all the way to the rear, where I used a small wooden dowel to get from there to the rear qtr. Then the same dowel to go from rear qtr to rear roof. This all took <1 hour.
The next 3 hours were disassembling the roof (which you can find instructions to in the navtv rear hatch closer install)
The hatch I was on my on, mostly just pull off the plastic trim slowly and carefully.
Yeah, I know what you mean about the roof liner. Took that all apart for the hitch electronics; real bitch.
For the PCM 3 it was no wires spliced into the factory harness and only 2 wires soldiered +/- for the camera from the provide harness. This assumes you are not using the provided video switcher for a front camera, which would add 2 more soldiered connections.
I have a 2005 CTT with PCM 2.1 so it may be different ... but I have a nav-tv unit with an Alpine camera. Picture quality is perfect .. even at night or in the sun ... more than I can say for my wifes Acura MDX. I highly reccoment the upgrade. I have kids so wanted the camera.
Appreciate the additional thoughts. I spoke with the service manager at the local Porsche dealership, he did have good things to say about the install company and mentioned he does recommend them for this type of work, however, he also indicated that if something went wrong with the electrical that I would have to take back to them to check it out first. Doesn't sound like a good idea considering my Cayenne is brand new. Probably still going to pass for now.
