Rough Idle, slow @ Full throttle
Old 03-10-2011 | 11:17 AM
Pavesi's Avatar
Pavesi
Default Rough Idle, slow @ Full throttle
Got my Cayenne 4.5 turbo S a few weeks ago (23k miles) and noticed it idles slightly rough and when given full throttle it seems to take off then get held back, and I hear a funny air type sound around 3000rpm.
I ordered 4 new coils ( hoping 4 were ok) took them out and they all look new, certainly no cracks.
Ordered ELM 327 code reader the other day, on runing a scan I got code P1090 and looking at the fuel trims, one bank is over 100 in the negaitve suggesting one knackered maf. Looking at real time monitoring I only see one maf reading does the ecu add the 2 mafs togather to calculate over all air flow?
I have 2 x recirc dump vlave to fit and 2 new mafs arrived today.
Is the above the right way forward??
cheers
Paul
Old 03-12-2011 | 07:19 PM
Pavesi's Avatar
Pavesi
no technical folks on here then??
Old 03-12-2011 | 10:29 PM
Andy E.'s Avatar
Andy E.
The V8 Porschephile
I also tried doing that here. It's no use. You're better off at the Renntech Cayenne forum as there's much more technical info there.
Old 03-13-2011 | 04:47 PM
Pavesi's Avatar
Pavesi
Thanks will give them a try.
Old 03-13-2011 | 05:37 PM
diesel2fast4u's Avatar
diesel2fast4u
no need, read real codes & post info.
I bet 1 coil went wrong, you have an 8 cilinder not 4
Old 03-13-2011 | 05:47 PM
Pavesi's Avatar
Pavesi
I know how many cylinders I have. I bought 4 coils hoping 4 would be ok ( tight jock, not a stupid one). They all look new deffo no cracking anywhere. I unplugged each coil inturn while the engine was running to see if one cylinder reacted differently, they all sounded thet same.
Real codes what do you mean? is P1090 not a real code??
Old 03-14-2011 | 06:56 PM
Pavesi's Avatar
Pavesi
All fixed. Going like a dream. Difficult job but well worth doing. Faster smoother and more responsive.
Quick Reply: Rough Idle, slow @ Full throttle
