Parts lookup guru needed
Old 01-23-2011 | 05:16 PM
yeldogt's Avatar
yeldogt
Default Parts lookup guru needed
Thanks to a few on the forum I understand the wiring in my 06 S enough to retrofit the e-bay sourced inside dimming mirror from a now departed 04.
Unfortunately, the parts supplier no longer had the 04 wreck to cut me out a section of the wire harness so I would have the correct connector to plug into the mirror.
I went to get a connector except the two parts guys at the dealer were less than helpful -- they really had no idea how to even look it up
Does anyone know how to look up this kind of part? What do they do at a dealership when something gets damaged? I guess tell you to forget it and buy a 2011.
Having to destroy the mirrors connector and wire it directly is something I would rather not do -- it will be much easier to make the new harness -- install it and then plug the mirror in.
Old 01-23-2011 | 06:06 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Give Jeff Clark at Sunset Imports Porsche parts a call ... He is a go to guy in these situations IMHO.
Quick Reply: Parts lookup guru needed
