No Air from HVAC System
Old 01-20-2011 | 03:37 PM
alsamrob's Avatar
alsamrob
Default No Air from HVAC System
Got in the Pig this am, and turned on the defrost. Started working fine, and then after about 30-45 seconds, some weird thumping noises, and then no air. Then it would make some more weird noises, and blow air for a little while, and then nothing again. Repeated all the way to work.
Anyone have any ideas? Going in to indie tomorrow, want to know what I'm up against.
Old 01-20-2011 | 05:25 PM
mudman2's Avatar
mudman2
Moderator !x4
If your getting heat thru I would suspect the $120 fan located above the passenger footwell
Old 01-21-2011 | 03:58 PM
alsamrob's Avatar
alsamrob
Yes, i get heat for about 30 seconds, and then the wind down starts. The fan gets weaker and weaker, and then just stops. In the shop right now, awaiting word.
Old 01-25-2011 | 02:02 PM
alsamrob's Avatar
alsamrob
Mudman, you were dead on again, at least for now. Indy replacing the blower fan today.
Quick Reply: No Air from HVAC System
