Mirror wire diagram
Mirror wire diagram
I ordered a dimming mirror from an 04 wreck to put in my 06 -- Does anyone know how to get a wire diagram for the mirror?
The connector on it has six wires -- also the mirror may have two LED ambiance lights on the bottom - can't imagine what else they would be. Can someone confirm this?
All I really need to have work is the dimming feature. So I just need to find a switched 12v line someplace.
I guess at least one of the other wires controls the outside dimming mirror on cars so equipped -- just not sure why it would need six.
Thanks for any help - my new route on the weekend is two lane and the truck lights are driving me nuts.
Thanks Loren -- I was not clear -- It is the inside rearview mirror I am referring to.
My car has all kinds of options -- but no dimming mirror. I wanted a CS with the sports seats and the blacked out exterior trim - never thought to look at the mirror.
I do have an overpriced carbon shifter!
Anyway -- The truck lights are beginning to bother my aging eyes and if I am going to keep this car I have to get a working dimming mirror. They should not make any Porsche without one.
I picked up an 04 mirror -- I just have to figure out the wires and getting a connector.
It looks like A4 and A5 send power out to the two outside mirrors to dim them - I do not have the dimming outside mirrors so I will not use those terminals.
A1 and A2 look to be the power for the mirror + and -
What I don't understand are the other two.
A3 connects to the reverse light control -- I'm wondering if this terminal is supplied with power + when you shift into reverse to turn off the dimming so the mirror is not dark when backing up?
A6 is called "inside lights" and connects to "EC Mirror" -- No idea what this is and if it is power in or out.
Any Ideas?
Any Ideas?
Went by the dealer this afternoon trying to see if I could pick up or order an electrical connector that will mate up with the mirror -- Parts guy tells me he needs the connector number ?? Its not listed on the connector?
I also can not confirm that the dimming feature of the mirror turns "off" when you shift into reverse -- can anybody with dimming confirm this?
The wiring diagram is definitely showing the two (mystery to me) connections as being inputs - most likely the reverse lockout and the other to turn on the small "ambiance" lights located on the bottom of the unit.
Nothing is easy.
Nothing is easy.
Need help with spoiler harness wiring diagram for macan(2016)&Cayenne958(2011 ) rear(
I need a wiring diagram (for macan(2016)&Cayenne958(2011) rear(tail) light )
- if someone has a technique forthat.
Would someone be able to post a wiring diagram of the harness wires I'd need totest and modify? I'd like to do the Cayenne rear light change to macan rearlight .
Need help wiring diagram for macan(2016)Cayenne 958(2011 ) rear(tail) light
