Battery Spec V8 2005
Hi Guys
Could someone tell me the battery size L*W*H and the Amps for Cayenne V8 2005.
Is there any online retailer for those batteries? are they easy to fit? the dealer charges US$ 550 to replace it, strange enough the labour cost is US$ 140
your help will be highly appreciated
Someone just posted the Interstate model that is it's replacement, use that and go to the Interstate web site and get it there (or just use the Interstate replacement).
Super Moderator
Needs More Cowbell
Needs More Cowbell
Group Size: 49H8
Voltage: 12
Cold Cranking Amps (CCA) @ 0°F: 800
Cranking Amps @ 32°F: 950
Reserve Capacity (minutes): 100ah
Terminal Type: SAE top post
Height (in.): 14-5/16
Width (in.): 6-7/8
Length (in.): 7-1/2
Weight (lbs.): 50
http://shop.advanceautoparts.com/web...GRPBATTAM2____
Voltage: 12
Width (in.): 6-7/8
Length (in.): 7-1/2
Weight (lbs.): 50
