03 CS transmission clunk,jerk,harsh down shifts
Hey guys i have 03 CS and when the transmission gets Warm it Down Shifts really hard from 3 to 2nd and once ive driven it for more than 20 minutes it starts to up shift hard also. what can the problem be? the vavle body for the transmission? maybe some type of reset can or might fix this???....I would really appreciate the help..thanks.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
How much does it run do something like that?? check the TCU & ECU? And how much does it cost to replace the valve body for the transmission parts and labor...?
Super Moderator
Needs More Cowbell
Needs More Cowbell
You can ask your dealer for a quote...and then shop independents.
For parts, Sunset Imports would be my first call.
Unless you have access to PIWIS, you wot be able to check nor update SW
The parts have been revised more than once and you have to have the correct controls for a specific valve body -- even the step motor was changed and I was told this required a control change.
I know that the early valve bodies had issues that caused this because I was told that my 06 had the newest one and so replacing it would not help - I had clunky sounding downshifts. The VB was evidently the usual suspect.
The largest improvements came from having the step motor changed - it was not moving to the fully "off" position -- do you ever get an intermittent 4 wheel drive warning?
Another surprise was how sensitive the transmission was to having the fluid level a little off.
In the end Porsche changed it all again (including the VB) also one of the mounts - to the newest revisions and I have never had the problem again. They could not pinpoint the exact part causing the problem ?
My '06 is in right now for the controller. I had the servo motor failure on the way down to Orlando last month, P of O replaced the servo motor and told me to get the (s/w matching) controller done at my dealer in Nashville. I had the valve body job done last year. Hopefully this will be the end of my transmission issues.
I'm glad this pepper is still under CPO coverage (until Oct.), otherwise this would be out of pocket. Still debating whether I'm going to keep it. If I unload it I would get better value if it still has some warranty.
Yeldogt: no I have never got the 4 wheel driving warning..I just have that hated "!"
Wirunner- that's another thing I wanted to do flush and refill the atf. Because I don't have warranty anymore I'm at 95xxx.
What is reason for the ...... i
I bet that changing the fluid is not going to fix your problem -- I'm not saying that a transmission with almost 100k on it would not benefit from a properly done change with the correct fluid -- but you may be doing it twice if the valve body is the problem. The fluid change procedure is a little complex -- and the fluid costs not insignificant.
Super Moderator
Needs More Cowbell
Needs More Cowbell
You can probably et access to a free code reader (some auto parts stores offer such service) to see what the "!" is related to.
FWIW, I don't recall a transmission flush on an alpha/beta fixing a clunk...
But who are we kidding, it's an 03. Your VB is shot!! Bend over for the dealer NOW!!
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Come on Lewis, I was trying to play nice and stay positive.
