question regarding cayenne turbo calipers
hi, i would like to know if cayenne turbo front and rear calipers are direct bolt on a cayenne S 2005?
if not, do you need adaptors?
also, which size rotors do you need for cayenne turbo front and rear calipers
to put on an 05 cayenne s
when looking at suncoast, they sell powerbrakes rotors at like 1200$ a set, are these the ones needed for turbo calipers?
thanks
a lot
thanks
a lot
Super Moderator
Needs More Cowbell
Needs More Cowbell
The power kit brakes were a OEM Tequipment kit and are larger than the standard brakes/rotors.
They were also installed on the Turbo S.
Turbo calipers red , S calipers silver.
The search function should provide lots of additional info and details.
There are 4 calipers, and one of them is available in 2 colors.
Cayenne 03-10 330mm rotor Porsche PNs 955-351-421-33, 955-351-422-33 (17Z Calipers, Black, Porsche 1LK Package)
Cayenne S 03-10 350mm rotor Porsche PNs 955-351-421-53, 955-351-422-53 (18Z Calipers, Silver, Porsche 1LL Package)
Cayenne Turbo 03-07 350mm rotor Porsche PNs 955-351-421-22, 955-351-422-22 (18Z Calipers, Red, Porsche 1LM/E0W Package)
Cayenne Turbo 08 368mm rotor Porsche PNs 955-351-421-70, 955-351-422-70 (Red, Porsche 1LP Package)
Cayenne Turbo 09-10, All Powerkits 380mm rotor Porsche PNs 955-351-421-61, 955-351-422-61 (19Z calipers, red, Porsche 1LH/E81 Power Package)
left to right...
18z, 19z, and the oddball 368
left to right...
![](http://www.goingsuperfast.com/sitebuilder/images/Cayenne_turbo_calipers-1-600x450.jpg)
awwdii (10-10-2023)
You might also want to check out ClubToureg.com. There is one guy on there (Touareg Owner) that sells rotors and pads. Guys are happy and save considerable amount of $$.
I am considering when the time is right.
