'11 CS - Air Suspension necessary/worth it?
Had air suspension on my 2008 Cayenne GTS, but I am not getting in on my 2011 Cayenne "S" and I tow a trailex open trailer.(would like to move up to an enclosed one, but not in the cards). I am getting PASM and I think that will serve my purposes while not having all the plumbing that goes with air suspension.
Can you tell me the tongue or ball weight is on your trailer. I am about to order a 2011 Diesel and will be towing a Yamaha 242L 24ft boat. it has 550lbs ball weight. I am trying to work out if the benefits of air out weighs the cost. I will not be taking it off-road, I am not that stupid, and the two lowered height are not really applicable as our maximum speed limit is 65MPH (110Kph) and is heavily enforced.
It also means that I can spend some of the $3000+ on other options.
Your thought would be greatly appreciated.
AVAWONDAFULXMAS
Cheers
Super Moderator
Needs More Cowbell
Needs More Cowbell
As mentioned earlier, air suspension is not required, it does not increase tongue weight capacity.
Also, PAG states that you can not use load sharing/distributing type hitches with air suspension.
There are many forum veterans who have towed with Cayennes since the early days...a search will yield their towing loads and observations.
Pepper Bartender
Pepper Bartender
It is good to be missed. I will attempt to do better... purplesaurus rex on backorder but will make do...... newbie chicken is important to the flavor of the pig forum... couldn't help myself posting my trailer pics with my air suspension equipped Tit.S..
