Seat Belt Buckle Plastic Housing Breaks
The V8 Porschephile
I'm quite surprised that nobody has mentioned this problem here on the Cayenne forum in Rennlist.
On two separate occasions and with different passengers, the plastic housing that surrounds the seat belt buckle (item no.17 in the below picture) comes apart at the seam and leaves only the skeleton structure.
When I called the dealer, they told me not to worry as they always keep at least one entire buckle ***'y in stock. Strange...
The V8 Porschephile
This actually happened to me today! So aggravated. When I purchased my 05 CS, the housing was already broken and my local dealership replaced it for around $150 w/ parts and labor. Since being ripped off by them on another occasion I have decided to not use them anymore. I've been looking around for the part to attempt a self replacement.
Anyone try the replacement themselves? BTW - I broke mine (center seat belt housing) when I tried to lay the back seat down to load some cargo.
The V8 Porschephile
The worse part is not knowing that it's broken and as you grab hold of the buckle, you shear off a few layers of skin in the process!
I actually tried using super-glue however with the type of ABS plastic that's used to make the housing, the glue doesn't work.
If you DO attempt to self-repair, as this is an SRS-related item, just remember to unplug the battery (just-in-case). Also, re-apply some lock-tite to the bolt threads when re-torquing. The rear seat-belt housing should be much easier to access than the front which requires seat removal.
