Cartronics Video in Motion module
Purchased this unit recently along with a FLIR Thermal Imaging Camera. The module is supposed to wire into the PCM and then out to an AV unit that allows 3 AV inputs to be displayed on the stock Nav screen.
Got it and read the instructions and it was WAY over my abilities. Went to 3 shops and then to two Porsche dealers and they wouldn't even try to do it.
The unit requires you to actually open the PCM and install a circuit board and switch out the screen ribbon into the board and I seriously cannot find any professional installer willing to try to do it anywhere.
Has anyone installed one of these? I am interested in seeing how hard you found it and if you have any advice if I try it myself.
Cheers
Cheers
any programmer will tell you no because if it doesnt work and causes permanent errors, youre out more than just an extra part...........an expensive OEM product they tampered with.......
