Squealing brakes
06 S. Picked it up three weeks ago. CPO car. Brakes squeal when I am coming to a stop. Don't recall hearing that 3 weeks ago. Is it normal? Has 45ooo miles no idea when last brake job was done but thought CPO cars came with at least 50% brake pads. Thoughts?
Caesar
Caesar
Rocky Mountain High
It comes and goes on our Cayenne.
Ours will generally do the same thing if they are super dirty. I would bet that if you took a hose to the inside of the wheels and the brake caliper you will get a TON of brake dust out of them. Should help.
Thanks, will try it out. Will an Electric pressure washer hurt anything behind the wheel, sensors etc. Hasn't on my other cars but you never know
I would imagine not, but I only use a spray nozzle on the end of a regular hose attached to the house. Nothing with the kind of pressure you'll likely get with a pressure washer.
My wife had this problem and it's what the dealer actually recommended to help. Obviously a pad that doesn't shed as much dust would help even more. But spraying out the wheels/calipers every time it gets washed or in between washes is pretty easy as well.
