Cayenne Dead Need Help!
#31
Thanks GoonBug, I'll check and clean those connections, just in case.
I contacted Porsche Latin America today, in order to see if they can get the Costa Rican dealer to accept my car. They seemed willing to help, but will have to wait and see if they actually help with this deal.
#33
My 2004 Cayenne TT refuses to start. The screen is red and says Steering Faulty and beeps. The shifter is locked. Car had to be put in neutral from below to be towed. Since ignition wont come on diagnostics cannot be run. Tech thought it might be ignition switch but changing that did not work. He is out of ideas and car has been dead since Thurs. Need some serious HELP!!
No luck with search...
#34
#36
This is going to become a more and more common problem as the components used in this circuitry get older. It is basically the same in the Audi A8, the VW Touareg and the Cayenne.
The official Porsche solution is to buy a new steering column, which including removal costs, replacement and recoding will run around $4000. There are some alternatives. Tom at Speedometer solutions in Chicago is very capable of fixing the actual problem, but you will need to send him the steering lock module (not too bad to remove but not for the feint of heart) as well as the kessy module and a functional key. The total cost for this depends on whether the lock was active or not, which decides if you can get the lock off with everything in place, or if you have to remove the steering column to get it removed. I would say removal costs will be around $250 or so. Tom charges $399 to repair the module and GUARANTEES his work.
The last alternative is to get all the necessary parts from a junkyard, but you will need the lock from the steering column, the kessy as well as the keys. You will then use all of the new electronics, and switch the blade from your old key. I have no idea what you could get such a set for but it will all need to be matching. Once these things are programmed, there is NO reprogramming.
I have just gone through this, and my car is back on the road after spending less than $500. Sucks but better than $4k...
#37
