Camber adustment
Lifetime Member
Lifetime Member
Camber adustment
Sorry if this has been discussed before.
Are the cambers front and rear adjustable on a 2006 Cayenne S without air suspension?
Last time I took the shocks off I didn't notice any specific camber adjustment bolts for it.
Well, the control arms are the same so I would image so. The fronts have camber bolts in them Simply loosen the two bolts and adjust as needed.
Not sure on the rear, I have not looked. I would imagine that even if they don't come adjustable you might be able to put in cam bolts and accomplish the same thing.
Front cam bolts.
There is one in each of the frame side mounts to move the arm closer or farther from the frame. You can see the two mounts here with the arm out.
Hope that helps at least some.
Front cam bolts.
