High frequency droning noise and vibration
You mean you're not supposed to be able to wiggle the center bearing an inch or more any which direction?! Mine's loosie goosie. I've been having the infamous low bass rumble (from about 60-75mph) and clunking into second gear when downshifting and sure enough, that POS cardon shaft is loose. Look at the decay on the bearing.
