2006 cayenne turbo S water coming out at corner of backside of AC
I have found my issue but it seems there is a ton of black plastic pipes that cover up the very hot metal pipes on drivers side. above the foot pedals. The water comes out warm and dips pretty fast. Start as soon as you turn the car on with the A/c on. Any hope would be appreciated
Do you still have the problem? When my A/c backed up this same thing happened, the water coming from the drivers side was dripping on my foot and was very hot! Sounds like you still have some water residue in there or still some more blockage up stream from the drain hose. I think you will just have to start pulling out some parts to find the blockage, good luck.
