Need some Advise For Cayenne PCM
Old 07-12-2010, 02:10 PM
hymhui
7th Gear
hymhui's Avatar
Default Need some Advise For Cayenne PCM
Hi guys, I'm trying to install a 08Cayenne PCM into my 04 Cayenne. I would like to know do I need any wire or clips or etc in order to install this head unit? Is it difficult to install? Any hardware I need to beware? Is it able to install the back up camera? Thanks alot!
Old 07-12-2010, 02:14 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,288 Likes on 806 Posts
Old 07-14-2010, 06:50 PM
Plastikos
Plastikos's Avatar
Does the '08 PCM have direct ipod or aux audio input? I need a new PCM as well and if this solves the ipod problem...
Old 07-14-2010, 08:20 PM
mudman2
Moderator !x4
mudman2's Avatar
Old 07-16-2010, 02:03 AM
bbcoach51
bbcoach51's Avatar
If you want Navigation with the 08 PCM you will have to add the DVD Nav unit under the passenger seat. If your 04 had PCM 2.0 and Nav you can use the existing antenna with an extension. For the iPod you will need a Denision or Mobridge type unit. I'm in the process of adding a back up camera via the Denison unit to my 04 which I upgraded the PCM to 2.1 from an 06.
Quick Reply: Need some Advise For Cayenne PCM
