Cayenne V6 Turbo Kit
Old 04-08-2010, 11:51 AM
touareg
touareg's Avatar
Default Cayenne V6 Turbo Kit
I don't have a V6, but I know people are always asking about this. Seems a little too good to be true for the price of ~$600.
11PC TURBO KIT PACKAGE
Included Parts :
( AS SHOWN IN AUCTION PICTURE )
T04E TURBO CHARGER
T3 Flange to Manifold
5 Bolt Downpipe Flange
3" Inlet Diameter & 2" Outlet Diameter
TURBO EXHAUST CAST MANIFOLD
Quality construction for increased street longevity
Large thick primaries
Manifold is made specifically for this vehicle
Equipped with a T3 turbocharger flange
27x7x2.5 UNIVERSAL H.P. LIGHTWEIGHT INTERCOOLER
2.5" outlet and inlet
Incredible 150 to 130 Degree Temperature Drop
INTERCOOLER PIPING KIT
(minor modifications may be required depending on application)
Universal Kit!
Stainless Steel T Bolt Clamps Included
Silicone Hoses Included
*38mm V-Band WASTEGATE
Utilized 35MM/38MM Flanges
V-Band top allows for quick changing of springs
Designed to efficiently release gas
Controls Turbo PSI
*BOV BLOW-OFF VALVE
High Grade Quality and Fit!
Relieves compressor surges + provides an aggressive sound!
CNC anodized!
*TURBO BOOST CONTROLLER
High Quality Fitment!
Conveniently adjusts PSI to reach your desired boost!
CNC anodized aluminum finish
*OIL CATCH TANK
JDM Greddy Styled Oil Catch Tank Can!
Made of the finest aluminum materials with a weather resistant coating.
Preserves Engine Life!!
*TURBO TIMER
High quality, ensures proper cool down time for turbo charged cars!
Slim Pen Design!
OIL DRAIN KIT
High quality fitting!
Extremely durable. Lasts a lifetime
Turbo Oil Drain
High strength oil drain line!
OIL FEED KIT
Turbo Oil Feed
High strength oil feed line!
AIR FILTER CONE
Ultra high flow!
Non-restrictive & Free-flowing!
APPLICATIONS :
Fits on vehicles below with these engines ONLY:
- VR6
NOTE :
* Not all parts are bolt-on. Universal piping kit will need to be custom modified at an exhaust shop to adjust for the correct bends. *
* Requires a down pipe which needs to be connected to existing exhaust. A custom adapter needs to be fabricated from a place such as an exhaust shop. *
* Professional Installation is Highly Recommended (No Instructions Included)!! *
*Item colors might vary from pictures depending on stock on hand please contact us, topstreetking@live.com for any requests.*
http://cgi.ebay.com/ebaymotors/02-09...Q5fAccessories
Old 04-08-2010, 12:16 PM
medtech
medtech's Avatar
Wouldn't a grenade be even cheaper?
Old 04-08-2010, 12:22 PM
RxPorsche
RxPorsche's Avatar
That is an universal kit, it will only give you problems and tuning headaches. Better buy an used CTT
Old 04-08-2010, 12:57 PM
Cole
Cole's Avatar
There are all sorts of VWs running heavily boosted VR6 motors with little issue.
Since the V6 is really a VW VR6 with a worked over intake I don't see why you couldn't start with a VW turbo kit.
I've seen GTIs with 500+WHP
Old 04-08-2010, 01:00 PM
Cole
Cole's Avatar
Here is one running 689hp (on race fuel). But you get the point.
http://www.youtube.com/watch?v=5eXc5CFhW0Y
Might be a sweet set up. Decent fuel mileage when not in full boost, but wicked quick when on boost.
Old 04-12-2010, 10:00 PM
charlieXS
charlieXS's Avatar
make no mistake... R32 Turbos can be NASTY. And yes, 500 at the RW is common. You can get a nice balanced kit with a cylinder head spacer to drop the CR to 9:1 and a better quality turbo and good parts for about $3500. Run 12-15 PSI and it's 400 at the RW (aka more than a GTS)
http://www.ctsturbo.com/catalog/MK4_...Kits-47-1.html
Quick Reply: Cayenne V6 Turbo Kit
