Continous Opening and Closing vent switch?
What is the vent like open close switch in the top of the dash in the middle for. The manual just says Continous Opening and Closing switch
I can not tell what that means or does.
Thanks!
Thanks!
Rocky Mountain High
Use the search tool... you'll find that this one has been discussed before.
The effects of the switch are very subtle. It's hard to tell if it's open or closed.
Moderator !x4
its simple. There are little creatures that man the aircon system. When you have the switch open the crumbs from your hoagie fall thru the vent and feed them, sometimes you can hear them at work
Is it called something different than what the manual states?
Thanks!
Ok, found a thread titled a couple of operating questions.
Basically for those that search for the words in the manual and hit this thread, the triangle is a vent and a speaker. I thought it was just a speaker.
